1 members (2-Ton),
150
0
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 24 Junior Member | | Junior Member Joined: Jul 2007 Posts: 24 | With a new rodsteration, there are a few bugs to be worked out, and i'm swatting at a difficult one to kill.
While in the garage, the hood latch holds tight, get her on the road, hit a bump, the main latch gives way, letting the secondary latch keep the hood from making visibility an issue.
Any key points or tips on adjustment, everything looks good as far as the operating levers and springs go... i usually run into hoods that are hard to open... not this one
by the way... she's got 42 miles on her now! | | | | | Joined: May 2005 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 44 | I would think the threaded stud in the middle might need to be lowered by rotating counterclockwise a couple of turns
Hello, Welcome to America press '1' for English Puess '2' to disconnect until you learn to speak English
| | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | That would be my guess as well. The stud in the hood that kinda floats, and is tensioned by a spring. Well, okay, mine floats. Don't know if it's actually supposed to, but my hood works fine. No visibility problems to date, except when it rains and I'm going up a hill. But that's another issue. 1951 3800 Be the change you want to see. -hotshoe
