7 members (Cletus1950, TexasJim50, klhansen, Otto Skorzeny, Jon G, 2-Ton, 1 invisible),
80
Mod | | | Forums66 Topics128,281 Posts1,058,460 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | I am looking for suggestions on how to remove the hood to cowl gasket without removing the hood. I have all but two of the clips off that hold it down....the two that I can't reach are the ones that are located as the gasket turns downhill. I have a 5/32 clutch bit but can't get the leverage to get them started as they are rusted. They have been soaking in PB Blaster for a couple of days. Any ideas? :confused:
Blue 50
1950 3100 w/57 235 Patrick’s Saginaw 4 speed and 3:55 rear end | | | | | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | If you want to be tricky about it, you could support the hood, undo the support springs and undo one hinge swivel on each side. You would need to guide the hood but it will move to a different resting place for you. This may or may not help you, only you can decide. | | | | | Joined: Jun 2006 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 272 | Are the screws long enough to begin an attack on them from under the dash?
1948 AD Pickup
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I know the ones on my truck can be seen from under the dash. | | | | | Joined: Jun 2006 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 272 | Mine too Virginiafiretruck, like about an inch long hangin' down there........
1948 AD Pickup
| | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | i made a clutch head driver out of a 3/8 drive alen wrench, and removed mine with the hood on, worked great,, | | | | | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | pushrod, I can see how that would work. There is not much room to get a grip on that screw, is there?
How did you go about making yours? I used my clutch head bit in a 1/4" drive ratchet, but then ran outa room on the two that I mentioned. I then used a 3/8" combination and put the bit in the closed end....need another hand to make it work though!!!
littlebuddie, I think if worse comes to worse I might try going after them from the inside but was worried about damaging the threads and then not being able to ever remove them.
Blue 50
