0 members (),
64
Mod | | | Forums66 Topics128,014 Posts1,055,325 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 92 | I have a new tank and sending unit. the new one has dual lines one pickup and a vent??? Can I just plug the one. I have a vent in the filler neck 1952 GMC 235 Dubl Duti Thanks Maxx
52 GMC Grumman Olson Kurb Side stepvan T3-8(Comet)69 GMC 1/2-ton
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Maxx, Yes..plug it, but do a good job, no cab fuel vapors are allowed.  If this new sending unit was the proper replacement, I wonder why it had the extra vent line? Maybe you should attach it to your gauge before you 'dunk it' and make sure it's the correct one. Stuart | | | | | Joined: Dec 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 92 | It is a refit of a 1984 GMC tank and sending unit it is a side mount no cab thanks Maxx
OH! Are you aware that the sending unit has a resistance value that must match the value of the fuel gauge. Most GM rigs of the '50's era used 30 ohm systems. A '84 will probably have a 90 ohm sending unit...this means your '52 fuel gauge will not read properly with your '84 sender. Just a thought!
Stuart | | | | | Joined: Dec 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 92 | Thanks Stuart Yes the 52 fuel gauge will not read properly I have 90 ohm sending unit and 12-volt 2" S-W that I will use Maxx
