0 members (),
144
8
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 42 | Hi guys, Just trying to figure out my rear end gear ratio without taking off the rear cover. If the input pinion makes 1 full turn and the tire turns 66% of a full turn, what's my gear ratio ? | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | oldkoot,
Here is a procedure I have seen posted on this site...I can't take credit for it. See if it works.
"Jack up one wheel. Mark the driveshaft and the wheel. Make 2 complete revolutions with the wheel & count the turns on the driveshaft. It should be fairly close."
Stuart | | | | | Joined: Sep 2006 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 42 | Stuart, If thats correct, and I'm doing the math correctly, the drive shaft will turn 3.3 times around for 2 revelutions of the wheel. | | | | | Joined: Sep 2006 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 42 | So I'm going to guess that I would have 3:31 gearing in my rear end as this seems to be the closest GM gear ratio I can find. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | To get a more accurate guesstimate turn one 10 turns while you count the other, then calculate. | | | | | Joined: Jun 2005 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 46 | i'm guessing its closer to a lower 3 series, unless its a posi rearend, you have to make 2 revolutions of the rear wheels to count the revolutions made by the driveshaft, so 2 divided by your .66 comes out 3.....there are 3.07 & 3.08 rearend gears, just depends on what the rearend is out of. | | | | | Joined: Sep 2006 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 42 | This is out of Caprice Wagon or Police Special as it has 12 x 2 brakes. | | |
