8 members (Jon G, Gdads51, mick53, 4tttt8, Leo, Otto Skorzeny, TUTS 59, 1 invisible), 87 guests, and 5 robots.
Topics128,181
Posts1,057,177
Members48,465
Hi guys, Just trying to figure out my rear end gear ratio without taking off the rear cover. If the input pinion makes 1 full turn and the tire turns 66% of a full turn, what's my gear ratio ?
oldkoot,
Here is a procedure I have seen posted on this site...I can't take credit for it. See if it works.
"Jack up one wheel. Mark the driveshaft and the wheel. Make 2 complete revolutions with the wheel & count the turns on the driveshaft. It should be fairly close."
Stuart
Stuart, If thats correct, and I'm doing the math correctly, the drive shaft will turn 3.3 times around for 2 revelutions of the wheel.
So I'm going to guess that I would have 3:31 gearing in my rear end as this seems to be the closest GM gear ratio I can find.
To get a more accurate guesstimate turn one 10 turns while you count the other, then calculate.
•1952 Chevrolet 3800 pickup
---All pictures---
i'm guessing its closer to a lower 3 series, unless its a posi rearend, you have to make 2 revolutions of the rear wheels to count the revolutions made by the driveshaft, so 2 divided by your .66 comes out 3.....there are 3.07 & 3.08 rearend gears, just depends on what the rearend is out of.
This is out of Caprice Wagon or Police Special as it has 12 x 2 brakes.
