1 members (Southerntruck), 134 guests, and 0 robots.
Topics128,192
Posts1,057,353
Members48,469
I am curious of the newest subframe out of a camaro you can use in a a/d truck? Reason I ask is I know where a guy hydro-planed and parked one on its top, I think his father said it was a 1991 with a V6 and a 5 speed trans. Thought maybe I could use the subframe, trans, and posibly the rearend.
Thanks in advance.
Collecting is fun, as long as momma enjoys riding in them.
With the strut design on those, it would be kinda difficult to use in your old truck. The trans you could probably use. Not sure about the rear end. My 1988 IROC rear end was too much trouble to modify to use like a stock rear end and I wouldn't want to set it up like the Iroc had it. Maybe it was just the IROC. Different seal / bearing from one side to the other, etc.
Junior Member
Junior Member
The axle will work, but will require removing all the coil spring mounts, etc. and welding on your spring mounts. I used an 87 (82-92 are interchangeable) and the TCI rear spring kit, worked out fine. The V-6 type are not super durable, tho, if you plan on towing or big power. +1 on staying away from the subframe.
Newest Camaro sub you would be able to use is the '81, all of the later ones either are strut cars or the upper control arms and cilover mounts to the body, not the frame.
Bill Burmeister
