8 members (TUTS 59, wilbur53, Joe H, tclederman, Charles in CA, kades51, 2 invisible),
74
7
Mod | | | Forums66 Topics128,187 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 35 | Here's a list of the roller bearings I installed on my 46 1/2 ton. If you're looking for the numbers and make, here they are:
Outer smaller bearing:
Brand--Timken #LM11919 and #LM11949 (one is the bearing, one is the race)
Larger inner bearing:
Brand--MBS #909052R (all one piece)
Seal:
Brand--Timken #6064
I think these will fit many other years as well, hope this helps you.
Possum | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Thanks for the info. I'm sure there are some here who can use it. Anything else people should know? Any problems with the install? Are they a direct swap in? Did you buy them locally at a bearing house or order them from a vendor? Thanks, Jeff
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Thanks this will be usefull | | | | | Joined: Jun 2006 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 35 | Hi Jeff, The parts are a direct install, using stock spindles and brake drums. Very easy to install, lube 'em up, slap 'em in. A local brake guy told me to tighten the bearings fairly snug, then back off about 1/4 turn. Seemed to work good, they spin easily and there is no wobble when I try to make it do so. I bought them from a vendor online thru ebay. I originally had purchased another set thru Bowtie Bits, but they were cheap Chinese bearings with no identification numbers stamped on them. I returned them, I wanted USA, Japanese, or German bearings. The Timken's are USA, the MBS are made in Japan. Much better quality than those ones Bowtie wanted to sell me. Have a nice day, Possum | | |
