6 members (NJC, latroca52, Leo, 2-Ton, Southerntruck, TUTS 59), 126 guests, and 3 robots.
Topics128,204
Posts1,057,302
Members48,467
Here's a list of the roller bearings I installed on my 46 1/2 ton. If you're looking for the numbers and make, here they are:
Outer smaller bearing:
Brand--Timken #LM11919 and #LM11949 (one is the bearing, one is the race)
Larger inner bearing:
Brand--MBS #909052R (all one piece)
Seal:
Brand--Timken #6064
I think these will fit many other years as well, hope this helps you.
Possum
Thanks for the info. I'm sure there are some here who can use it. Anything else people should know? Any problems with the install? Are they a direct swap in? Did you buy them locally at a bearing house or order them from a vendor?
Thanks, Jeff
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
Thanks this will be usefull
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
Hi Jeff,
The parts are a direct install, using stock spindles and brake drums. Very easy to install, lube 'em up, slap 'em in. A local brake guy told me to tighten the bearings fairly snug, then back off about 1/4 turn. Seemed to work good, they spin easily and there is no wobble when I try to make it do so.
I bought them from a vendor online thru ebay. I originally had purchased another set thru Bowtie Bits, but they were cheap Chinese bearings with no identification numbers stamped on them. I returned them, I wanted USA, Japanese, or German bearings. The Timken's are USA, the MBS are made in Japan. Much better quality than those ones Bowtie wanted to sell me.
Have a nice day,
Possum
