7 members (Wayne67vert, baldeagle, 74cheyennesuper, NorCal52Suburban, Ponchogl, Peggy M, NJC), 60 guests, and 4 robots.
Topics128,014
Posts1,055,328
Members48,419
#236529 07/02/2007 5:55 AM
on my 67 283 the battery almost melted theres a bracket on the front that goes up and bolts to the block . Well it came loose and fell on the cable and starter things got hot and I got a tow home so now i got new cables and everything is fine except i cant get the front bracket back in can i go without it i see most starters dont even have the front bracket is it realy needed if so mayby i can get it jacked up enuff theres not much room for to top bolt because of the manifold let me know what you think thanks guys for the help
#236530 07/02/2007 6:47 AM
On my last 283, that bracket saved me from a walk home when one of the starter bolts broke. It was just enough to hold the starter in place with one bolt.
1947 Chevy 6400 Wrecker
Old Stovebolts don't leak oil
They just mark their territory
#236531 07/02/2007 6:48 AM
3B Offline
Hy 32fire2, Your right, most starters don't use the front support, and there doesn't seem to be a lot problems caused by that, just make sure the bolts holding the starter to the engine are torqued to spec., hope that helps.
#236532 07/02/2007 9:42 AM
yes i will make sure the starter bolts are tight they may be loose also
#236533 07/02/2007 9:44 AM
i just wanted to make sure it wouldnt crack the starter mounting or housing but it sounds like it will be ok
#236534 07/02/2007 1:39 PM
Never even seen one with a front bracket.
#236535 07/02/2007 6:25 PM
I didnt put the bracket on my 55 for clearance reasons.The starters been on for 4 yrs. with no problems.
#236536 07/02/2007 9:43 PM
Riding in the Passing Lane
If the starter has three bolt horizontally into the bell housing it doesn,t need one. If it has 2 vertical bolts parallel it does need the bracket. If the vertical bolts are staggered It doesn,t need it but it is beter with it.
1972 Chevy c10 Cheyenne Super
