5 members (Hotrod Lincoln, carbking, Ponchogl, delky, Otto Skorzeny), 150 guests, and 2 robots.
Topics128,196
Posts1,057,385
Members48,471
Hi everybody! I'm sure its been asked before but here's my situation. I've got my 1960 chevy project truck that I tinker with here & there. I've always wanted to stick with the 235 & torsion bar front end but have found that parts are not so plentiful for it. My cousin restored grandma's 69 recently & shortly after doing so found a rolled late model 4X4 So he converted it to 4 wheel. He has the newly rebuilt coil spring front end just sitting & offered it to me for the price of a 6 pack of his favorite beverage. And I can have the 350 & auto trans from the rolled burb for the same price if I want it. It's not a 235 but the price is right. Anyways, is this front end swap a bolt it up & go or is it a major mod job?
I've heard of people making that swap, but have never seen a write up giving the details of how it was done.
The motor and trans swap part should be straight forward. The side mount small block was an option in that truck, and the T350 mounts the same as the later Powerglide which was an option in that same series of trucks. I'm sure you'll have some work ahead to make it work.
A friend gave me the front crossmember from a '67 to use in my '60.Gave it back to him.A couple of the mounting holes lined up but the others would need to be drilled.It would work with minimal effort I believe but I just decided to retain the original torsion bar setup grin
Current project . . . 1960 LB stepide Chevy
thanks for the feedback guys. It sounds like I may be better off to stick with the original plans. I'll look it over in the next weekend or so.
Nice project you've got there halfpint33. Mine is the long bed step side as well. my dad bought it second hand the week I was born & it lived through my brothers, me & several others learnin to drive and being our high school vehicle. That is one tough truck. It finally died several years back when my nephew ran the rear end out of juice. It sat for quite a few years out in a field after that. I put a rear end in it & moved the wifes minivan out of the garage to give it a home. I've got a long way to go to get it back on the road.
Thanks again & good luck with your projects!
