Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Phak1, Tom McGrath), 119 guests, and 1 robot.
Topics128,274
Posts1,058,433
Members48,490
#236284 06/25/2007 5:31 PM
first off, it's a 51, 3100, my problem is that when the brakes are cool it stopes fine but when they get hot it pulls hard to the right, i've replaced all but the right front wheel cylinder, all new hoses and lines :confused:
#236285 06/25/2007 7:07 PM
pushrod,
51 1/2ton should be bendix,Correct, NOT Huck Style,My 51 is bendix.....
The rt front W/C COULD be hanging up.....
You already said you replaced ALL the hoses,that eliminates a collapsed hose not letting the W/C release.....
Make sure you have Both front brakes adjusted correctly,in other words try backing the right side off a tad,could be too tight,compared to the L F Brake.....
regards,Steve Sr.
#236286 06/25/2007 8:22 PM
pushrod,
Are the Drums original,New or turned?
In other words I like to keep both brakes,Especially the fronts, The same.
Compounded with a slight difference in adjustment...
A New Drum is gonna grab different than a used or unturned one wink
Regards,Steve Sr.
#236287 06/25/2007 9:03 PM
i need to correct myself, it pulls to the left not to the right, both drums are orig. and in good shape, and the shoes are in good shape as well, i will try adjusting them and see if that cures it,, one more thing, the left ws was leaking befor i changed it, would fluid on the shoes caues this problem? i cleaned them with brake cleaner,
#236288 06/25/2007 9:19 PM
Riding in the Passing Lane
You need to replace the shoes when they get fluid or grease on the linings. You can clean them forever & the next time they get hot more comes to the surface. You should o-haul or replace all the wheel cyls & master cyl. on these old trucks as soon as you get one. The old fluid soaks up moisture & turns to crud. It eats away at the cyls.
1972 Chevy c10 Cheyenne Super
#236289 06/25/2007 9:39 PM
thank you for the info, i'll order some shoes for it,,,ron
