3 members (Hush, dt235sd, 1 invisible),
164
0
Mod | | | Forums66 Topics128,080 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 26 Apprentice | | Apprentice Joined: Jul 2006 Posts: 26 | Can anyone tell me the thread size of the cab and bed mounting bolts on a 1946 1/2 ton? Also I believe the cab is mounted with 6 bolts. How many does the bed require?
Thanks | | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | If you go to Carters or Bow Ties and Bits I believe they have pictures of the kits complete with bolts. I don't know the size of the threads but they are fine thread and the rear ones have holes through them for mounting small springs and cotter pins and you are correct there are six . You might have to purchase a set if you want to replace them. The kit comes complete with wood blocks, nuts, bolts and springs etc. Hope this helps. Bob T | | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | Here is another source for the info and parts you seek WWW.mar-k.com
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
