0 members (), 38 guests, and 4 robots.
Topics128,089
Posts1,056,004
Members48,430
#236013 06/20/2007 12:34 PM
Apprentice
Apprentice
1 Offline
Can anyone tell me the thread size of the cab and bed mounting bolts on a 1946 1/2 ton? Also I believe the cab is mounted with 6 bolts. How many does the bed require?
If you go to Carters or Bow Ties and Bits I believe they have pictures of the kits complete with bolts. I don't know the size of the threads but they are fine thread and the rear ones have holes through them for mounting small springs and cotter pins and you are correct there are six . You might have to purchase a set if you want to replace them. The kit comes complete with wood blocks, nuts, bolts and springs etc. Hope this helps. Bob T
Here is another source for the info and parts you seek WWW.mar-k.com
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
