4 members (Tom McGrath, TexasA&M48Truck, Otto Skorzeny, Gdads51), 97 guests, and 2 robots.
Topics128,094
Posts1,056,051
Members48,433
#23569 04/04/2005 10:55 PM
AJ
Offline
Junior Member
Junior Member
Hi. Can unleaded fuel be used in a 1969 250 straight six. The vehicle is a Grumman Olsen Stepvan that I bought here in England in 1978. At the moment I am using a lead replacement additive in the fuel, but was wondering if the engine would be damaged if I was to stop using it?
#23570 04/05/2005 2:03 PM
Junior Member
Junior Member
I use unleaded in mine said to wear valve seats there are many opinions on how fast the only way to prevent this is with additives or having hardened seats installed in your head and new valves I'm running mine with unleaded and when the time comes I'll have the head redone
#23571 04/05/2005 2:30 PM
I used unleaded in a 250 for years with no ill effects.
Buzz'n Half Dozen
#23572 04/05/2005 4:33 PM
Junior Member
Junior Member
Someone credible told me some time ago that if a vehicles engine has at least 50,000 miles on it running leaded gas, that it will be fine without additives if you switch to unleaded.
#23573 04/05/2005 9:58 PM
Riding in the Passing Lane
If it was in a car or 1/2 ton pickup I would say you would never have a problem. These step vans pull real hard on an engine. I would use an additive or put on a later model head unless you just run it till it wallers out the seats & than put in hardened seats or use a later model head. 1971 or later. If you need body parts for that grumman I know a good place to get them. Post it if you are interested. I repaired & sold step vans for 35 years. smile
1972 Chevy c10 Cheyenne Super
#23574 04/08/2005 3:12 AM
Tab Offline
I wouldn't worry about it.
delete my account and pictures
