4 members (NJC, Oswald, 2 invisible),
132
Mod | | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#23550 05/14/2003 4:30 AM | Joined: May 2003 Posts: 11 Junior Member | | Junior Member Joined: May 2003 Posts: 11 | I have a 1951 Chevy Pick Up with a 235 that is hard to start when it is hot. It starts great when it is cold and if it is restarted shortly after turning it off (such as when I go to get gas). But if it sets for more than about 10 minutes, it will not start easily. The engine does not seem to turn over as fast when it is hot. I can usually push start it and get it going. After it cools down it will start fine again. It still has manual choke and throtle and foot starter. Any ideas would be appreciated. | | |
#23551 05/14/2003 8:04 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Have you checked and cleaned the cables to the starter and the ground?
The starter may be getting a little tired. Oh, have you checked and set your dwell & timing?
#23552 05/15/2003 2:55 AM | Joined: May 2003 Posts: 11 Junior Member | | Junior Member Joined: May 2003 Posts: 11 | Yes I did check / clean the battery cable and ground connections. I also had the starter rebuilt. The one thing I did not do was take the advice of the guy who rebuilt the starter. He said to get a bigger battery cable - about as big around as your thumb (00 maybe ???). I may try it.
I have not checked timing and dwell but will do so. | | |
#23553 05/15/2003 3:04 AM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Is your system 6 or 12 volts ? When mine was 6 I always had problems starting after the engine was really hot (such as idling in line at the dump). So as soon as I shut it off to unload my truck, it was almost a certain thing that I would not be able to restart the truck until after the engine cooled down a little.
Then I switched to 12 volts & the problems for both extreme hot and cold temps have gone away....
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#23554 05/15/2003 6:31 PM | Joined: May 2003 Posts: 11 Junior Member | | Junior Member Joined: May 2003 Posts: 11 | It is 6 Volts. When I bought the truck it was my intent to convert it to 12 Volts. But I feel like I am so close to getting the 6V to work that I hate to give in. Seems like converting to 12V would just mask another problem. It is good to know that 12V solved your problem and that it is an option if all else fails. | | |
#23555 05/15/2003 6:51 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Joe, Do a search here on the page. The 6 volt cable problem has been written about a few times. Click here for one thread You need at least a size 2/0 battery cable on both the positive and negative side of the battery. I had mine made up at a shop that services larger trucks. Be sure to connect the ground to a spot as close to the starter as possible. Also make sure you have a good ground strap or cable between the frame and the block. I am betting that a cable change will solve your problem. My 6 volt system spins as quickly as any 12 volt set-up..
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#23556 05/15/2003 7:23 PM | Joined: Aug 2002 Posts: 221 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Aug 2002 Posts: 221 | Hi Joe M!
I had an identical problem with my 46. It has a 235 engine and a 6 volt system. I cured the problem you have with a bigger ground cable. The positive was the correct size but the ground was more in keeping with a 12 volt. The bigger ground cable, connected to the starter mount bolt, fixed the problem. Hope it does for you. George | | |
#23557 05/15/2003 7:35 PM | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | Another thing to look for: If the engine has been rebuilt, there may not be sufficient piston clearance. Dont laugh, a fella with a 55 1st series had to re-do his engine for that reason... | | |
#23558 05/15/2003 7:37 PM | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | Then again, I had the same problem my my 53. A good re-charge of the battery was sufficient to fix the problem... | | |
#23559 05/16/2003 3:43 AM | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | Go with the biggest cables you can find,6 volt systems can use all the help it can get and definately check the timing. Jeff | | |
#23560 05/16/2003 3:10 PM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I had the same problem on my 235. When I replace the electrical harness, I found a nearly broken wire from the coil to ground. The problem went away after the new harness but I always suspected that wire. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#23561 05/16/2003 4:58 PM | Joined: May 2003 Posts: 11 Junior Member | | Junior Member Joined: May 2003 Posts: 11 | Another question - the starter on my 235 is from the original 216 engine - should this matter? Does the 216 starter have enough umph for the 235? | | |
#23562 05/18/2003 4:52 AM | Joined: May 2003 Posts: 11 Junior Member | | Junior Member Joined: May 2003 Posts: 11 | I think I have answered my own question on the 216 starter. From what I have read it sounds like it should be ok. Thanks to all that have responded to the initial question. Being a rookie at this, I will have to say that this forum is a great way to learn. I'm looking forward to trying many of the suggestions. | | |
#23563 05/18/2003 5:19 AM | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | Are you using a 235 of 216 flywheel,I have heard they are different as they use different tooth count flywheels and they wont interchange.You might want to look into this before you try to install a 235 starter. Someone out there should know if this is correct. | | |
#23564 05/18/2003 6:48 AM | | Anonymous Unregistered | | Anonymous Unregistered | If ya have good ground wires & a good battery & ya are still gettin' ru ru ru it sounds like the field coils in the starter are fried. Time for a rebuild. | | |
#23565 05/18/2003 8:22 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I set up my 261 to use my 216 starter by having the flywheel machined for the 216 ring gear, it worked out nice.
#23566 05/19/2003 3:58 AM | Joined: Apr 2003 Posts: 8 Member | | Member Joined: Apr 2003 Posts: 8 | HEY JOE: I had a similar in my 54 Chrysler six volter. I bought a OPTIMA battery and it has more and longer cranking power. It was about $ 100.00 but I didn't have to convert to 12 volts and it will outlast a number of lead acid batteries. Worth the money to me. GOOD LUCK | | |
#23567 05/24/2003 7:35 PM | Joined: May 2003 Posts: 11 Junior Member | | Junior Member Joined: May 2003 Posts: 11 | I think we have success! I had some big cables made (2/0) and put one from negative termimnal on the battery to the mounting bolt on the starter. So far so good. I have been able to start every time - hot or cold. Thanks for all the good advice guys. | | |
#23568 05/27/2003 8:14 PM | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | Joe M.
Had the same problem with my '54 235...if bigger cables helped, great.
A number of "greybeards" have told me to have the starter motor re-built using "hi-torque" field coils....will try this if I get backed-into a corner.
Have not yet been forced into a 12-volt conversion on any of my old iron....
Frank McMullen
Frank McMullen 1941 Chevy dump truck 1949 GMC 100 pick-up 1954 Chevy 3600 pick-up 1955.1 4400 dump truck 1941 De Soto & other MoPars 1928 Model A F**D Special Coupe
