0 members (),
186
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 71 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 71 | will a 60-61 hood fit on a 62-66? are chevy and gmc hoods the same? thank you | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | It'll bolt on, but they aren't the same.
On the '62-'66 hoods, the lower panel that houses the marker lights/turn signal housings is different between Chevy and GMC. Look at examples in the gallery to see what I mean. The shape of the lights is different, and the openings in the leading edge are different.
The cowls on the '60-61 Chevy and GMC also have different inserts. Again, they're all interchangeable, just not "correct." I'm going to put a '62-'66 GMC hood on my Chevy, because I like the look of the openings.
-Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Oct 2004 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 40 | thanks brad: so cosmetic differences aside if i purchased a 66 gmc or chevy truck i could easily put on a 60-61 hood without having to make any modifications? i know that i am probably in the minority but i like the look of the 60-61 hoods. thank you. | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | As far as I know, you should be able to make that swap. I thought very hard about doing the same thing with my '62 Suburban, but was over-ruled by The B's...The Boss and The Boy. I did swap in a '60 4-headlight grille though, and love it.
-Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The '60-'66 Chevy and GMC hoods are interchagable, between years and brands, although not period correct. The four lamp grilles look pretty slick.
Tony | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | four lamp grills are neat, but i also like the single w/ chrome like your "BCKNBLK" Tony. it reminds more of an 70's-80's vintage 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Mike:
You have seen my rigs and know that I am a purist. I prefer the stock appearance of the '64-'66 Chevy trucks over the others of the era, however the four lamp grilles look good, as well.
Do you have any updated pictures of your '63 Chevy K10? We need to see the progress.
Tony | | |
