4 members (Bill Hanlon, Wayne67vert, eclector, Otto Skorzeny), 92 guests, and 3 robots.
Topics128,034
Posts1,055,533
Members48,425
#235112 06/03/2007 1:15 AM
I have a 1949 3100 that I have been working on, and haven't driven in awhile. The speedometer does not seem to be reading right. It read slow at slower speeds (5-30 mph), but by the time it gets to 45 mph it is pretty much on. I checked the speeds against a GPS, plus I can just tell at slower speeds its not reading right. Any ideas?
#235113 06/03/2007 1:31 AM
Posibly the cable is sticking/binding.
Bill Burmeister
#235114 06/03/2007 1:37 AM
Cable works smoothly. Needle does not jump or bounce.
#235115 06/03/2007 1:48 AM
Then most likely the problem is in the speedo head itself. I really can't give you too much info on what could be making read wrong. I did have a similar problem, reading low,then pegging at higher speeds, ended up replacing the speedo head with one from a different truck.
Bill Burmeister
