| | | Forums66 Topics128,049 Posts1,055,548 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 32 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 32 | I have a 1949 3100 that I have been working on, and haven't driven in awhile. The speedometer does not seem to be reading right. It read slow at slower speeds (5-30 mph), but by the time it gets to 45 mph it is pretty much on. I checked the speeds against a GPS, plus I can just tell at slower speeds its not reading right. Any ideas? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Posibly the cable is sticking/binding.
Bill Burmeister | | | | | Joined: Mar 2006 Posts: 32 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 32 | Cable works smoothly. Needle does not jump or bounce. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Then most likely the problem is in the speedo head itself. I really can't give you too much info on what could be making read wrong. I did have a similar problem, reading low,then pegging at higher speeds, ended up replacing the speedo head with one from a different truck.
