| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 11 Junior Member | | Junior Member Joined: Jan 2007 Posts: 11 | A couple of questions:
1. Does anyone know where I can purchase the Rubber Bumpers that are used on trucks with the Auxiliary Springs? I have tried about 10 different suppliers without any luck.
2. I am looking for a copy of the Parts Lists, which list the original part numbers for my truck – 1968 Chevrolet.
Any help would be appreciated.
Thanks, Larry Hull
None
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I don't know anyone with that new a truck  Hold on and someone will know. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 1 - you're probably looking for good used 2 - get an assembly manual , tho original numbers don't do much except let the GM dealer tell you faster that the parts not available Bill | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | | | | | | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | The Filling Station in Lebanon, Oregon has more replacement rubber pieces than I've seen anyone else carry. They have a website with an online catalog. Give it a try.
Neil 1940 GMC 1/2 Ton
