3 members (David Bush, 52Carl, Jon G), 136 guests, and 13 robots.
Topics128,078
Posts1,056,029
Members48,433
#23494 08/03/2003 11:18 PM
Question for the list...on my 216 motor the
oil pan gasket is all cork..also both ends
When I installed it and tightened it down
it leaked perfusley near the flywheel end
I don't believe it was the rear main seal
It seemed to come down near the pan..no oil
ran down the flywheel..Do you think the oil
pan should have neoprene rubber ends..
1946 chevy 1/2 ton panel
1937 ford coupe
#23495 08/04/2003 1:17 AM
Nope ,, just more gasket cement .
#23496 08/08/2003 2:38 AM
I had this same problem with tranny gasket. Guy that helped me replace gasket used an air drive to tighten down the tranny pan. 1 month later had tranny fluid leaking. I replaced the gasket and this time used a little gasket sealer,and tightened by hand. No problems after that. The old cork gasket I removed had actually been split in two from over-tightening.
1964 Chevy C-10
#23497 08/08/2003 4:52 PM
If you overtighten the oil pan you are changing it's shape. It doesn't want to be very tight.
I glued the cork gaskets on the oilpan with a semi permanent gasket sealer and let that dry. Then I applied a healthy amount of regular gasket sealer on the top and installed it. Just tighten careful.
54 3100 with 235
62 flatbed dump C60 with 261
#23498 08/08/2003 8:39 PM
You can also use some rtv on the ends of those gaskets to seal them. Straighten the pan and use a torque wrench.
Fred
52 3600
69 C-10
