| | | Forums66 Topics128,078 Posts1,055,936 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#23494 08/03/2003 11:18 PM | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | Question for the list...on my 216 motor the oil pan gasket is all cork..also both ends When I installed it and tightened it down it leaked perfusley near the flywheel end I don't believe it was the rear main seal It seemed to come down near the pan..no oil ran down the flywheel..Do you think the oil pan should have neoprene rubber ends..
1946 chevy 1/2 ton panel 1937 ford coupe | | |
#23495 08/04/2003 1:17 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Nope ,, just more gasket cement . | | |
#23496 08/08/2003 2:38 AM | Joined: Aug 2003 Posts: 11 Member | | Member Joined: Aug 2003 Posts: 11 | I had this same problem with tranny gasket. Guy that helped me replace gasket used an air drive to tighten down the tranny pan. 1 month later had tranny fluid leaking. I replaced the gasket and this time used a little gasket sealer,and tightened by hand. No problems after that. The old cork gasket I removed had actually been split in two from over-tightening.
1964 Chevy C-10
#23497 08/08/2003 4:52 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | If you overtighten the oil pan you are changing it's shape. It doesn't want to be very tight.
I glued the cork gaskets on the oilpan with a semi permanent gasket sealer and let that dry. Then I applied a healthy amount of regular gasket sealer on the top and installed it. Just tighten careful.
54 3100 with 235 62 flatbed dump C60 with 261
#23498 08/08/2003 8:39 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You can also use some rtv on the ends of those gaskets to seal them. Straighten the pan and use a torque wrench.
Fred 52 3600 69 C-10
