| | | Forums66 Topics128,088 Posts1,055,993 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | Just finished taking the drums off the 50 3600, a job in itself. but the question is, on the one 50 it has the huck brakes. no surprise there, but when they came off the spring was broke on one and had to force the adjuster on the other, so of course you know that that one is trash.... so went down and brought up the other 50 figured we could use the parts of it, well guess again it has the bend ix set up,, don't understand that one either...well still have the 47 4100 and it looks like the huck brakes on that... question is will the parts cross from the 47 over to the 50 before i take them all apart.... cannot find my books since we moved into the new house.. any help ..... | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Can you change backing plates and all to go from Huck to Bendix? | | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | may give that a shot Grigg if the others will not work. shoes and drums are good on both. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I'd try to swap the Bendix brakes. On the ½-ton it involves drilling out some holes in the spindle. The ¾-ton is probably similar. | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | As cletis mentioned, the 3/4 ton is similar to the 1/2 ton Bendix swap. The top holes on the spindle need to be drilled out to 1/2", and that's about it. I am currently doing this swap on my '52 3600. | | | | | Joined: Sep 2006 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 47 | The 1/2 ton drums are 6- lug, and I don't think they'll fit the 3/4 hub and the 1/2 ton hubs won't fit the 3/4 spindle, so I think you'd have to change out the complete axle and run 6-lug on the front and 8-lug still on the rear? Think I'd repair the Hucks. | | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | thanks for the replys, what through me off was that both of the 50's are 3/4 tons. don't figure why one had huck and the other bendix. thought maybe someone had did a swap before but everything looks stock. will still bring up the 4100 and take a look at the huck setup on that one before i change everything over, the brakes look good just need a spring and one ajuster side for the back. will let you know that outcome.. thanks for the feed back | | |
