15 members (Jims46, Southerntruck, joe apple, Otto Skorzeny, Hawkman, J Lucas, D B Cooper, Oldcaliforniakid, Stovebolt48, Bill Hanlon, Peggy M, DadsFirstPickup, Ponchogl, Hotrod Lincoln, 1 invisible),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,674 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 51 | Hi
I'm putting power steering in my 55 1st serie Chevy Truck and need a Pulley for my rebuild earley Chevy steering Pump. The old Pulley has been on the shaft without a nut an anything else but it broke when I pulled it off.
So I'm here in Germany and I can order a pulley with 625 in. Bore. Does that fit??
My shaft is 19mm but I am not sure what that is in Inch, maybe 482 in. ??? | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Bernd, .3937 X 19mm = .748...almost 3/4". Stuart | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The older pumps had a smaller shaft with a keyway & a nut holding it on. The later ones had a larger shaft & the pulley was an interferance fit & pulled on by a tapped hole in the shaft with a special tool. I,m not shure of the dementions but I can check when I get to the shop tomorrow. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Benrd can you post a picture of your old pulley and the shaft on your pump I have a number of pulleys in both the press fit and the ones with the nut. If I can be sure I am sending the right one I will be happy to send it to you. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 |
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2006 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 51 | Hi
I could send you a Picure with an e-mail but I have no idea how to post a picture from the pump or Pulley.
Thanks | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | bartamos,
Right you are, sorry and thanks! :o
Stuart | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The small shaft is 5/8" dia. 0.625 15.875mm. The large shaft is 11/16" 0.6875 17.4625mm. There are so many different offsets & outside dia. we would need to see a photo to match it up. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
