1 members (1 invisible), 80 guests, and 0 robots.
Topics128,049
Posts1,055,679
#234751 05/25/2007 9:51 PM
Hi
I'm putting power steering in my 55 1st serie Chevy Truck and need a Pulley for my rebuild earley Chevy steering Pump. The old Pulley has been on the shaft without a nut an anything else but it broke when I pulled it off.
So I'm here in Germany and I can order a pulley with 625 in. Bore. Does that fit??
My shaft is 19mm but I am not sure what that is in Inch, maybe 482 in. ???
#234752 05/25/2007 10:12 PM
Bernd,
.3937 X 19mm = .748...almost 3/4". smile
Stuart
#234753 05/25/2007 11:06 PM
Riding in the Passing Lane
The older pumps had a smaller shaft with a keyway & a nut holding it on. The later ones had a larger shaft & the pulley was an interferance fit & pulled on by a tapped hole in the shaft with a special tool. I,m not shure of the dementions but I can check when I get to the shop tomorrow.
1972 Chevy c10 Cheyenne Super
#234754 05/26/2007 1:57 AM
Benrd can you post a picture of your old pulley and the shaft on your pump I have a number of pulleys in both the press fit and the ones with the nut. If I can be sure I am sending the right one I will be happy to send it to you.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
#234755 05/26/2007 1:58 AM
Sir Searchalot
Sir Searchalot
It's .03937
#234756 05/26/2007 3:06 PM
Hi
I could send you a Picure with an e-mail but I have no idea how to post a picture from the pump or Pulley.
#234757 05/26/2007 4:49 PM
bartamos,
Right you are, sorry and thanks! :o
Stuart
#234758 05/26/2007 9:02 PM
The small shaft is 5/8" dia. 0.625 15.875mm.
The large shaft is 11/16" 0.6875 17.4625mm.
There are so many different offsets & outside dia. we would need to see a photo to match it up.
