2 members (Tronman, Gray_Ghost), 85 guests, and 1 robot.
Topics128,142
Posts1,056,476
Members48,441
#234677 06/09/2007 10:14 PM
I have a 51 GMC truck, but I switched the steering arms, drag link, and pitman arm to parts off a 53, which had the tapered holes instead of the ball studs. The problem is that my drag link is worn out, with no rubber boots and I can't get the nut off. I have heard about making an adjustable one, but I don't know what the correct parts for it would be. I have found this website and I was wondering if these tie rod ends fit the tapered holes in my 53 steering arms: http://www.stockcarproducts.com/susp8.htm
Which ones would be appropriate? If any of these fit, I can buy two ends and a tie rod tube to make an adjustable drag link.
Wish I could help Justin but i replaced my front suspension with a Mustang II. I'm sure there will be plenty of answers to your question real soon.
Your Webshots documentation looks very good.
Good luck.
~Jim
