4 members (k2handyman, moparguy, dt235sd, Hotrod Lincoln), 71 guests, and 1 robot.
Topics128,049
Posts1,055,678
#2344 05/16/2003 1:24 AM
Junior Member
Junior Member
Not sure if I am in the right forum for this? But I have been following chipheads saga, as my 235 needs to be rebuilt. I have a 283 that out of a 64 impala that's begging for a home. I currently have a 3 speed OD in the truck and plan on keeping it. I am going to pick up the stock V-8 bell housing for my 57 this weekend. My question is, the 283 mounts the starter on the motor, the stock bell housing mounts it on the bell housing, so which starter will I have to use? Will the stock bellhousing starter clear the ear that's on this 283 where the starter bolts on that motor? Thanks for all your help you guys are great.
Willy 57
#2345 05/16/2003 3:37 AM
The 235 bellhousing is different than the 283,its got a different bolt pattern. Depending on what year of truck you have and if a V8 was optional you will need to get the V8 bellhousing,flywheel,clutch parts,starter,mounts and other parts. The 63-up V8 and six manual bellhousings are where the starter bolted. Jeff
