| | | Forums66 Topics128,091 Posts1,056,036 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 324 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 324 | I have been driving a '47 1/2 panel for about ten years on and off. The wipers have worked o.k. in the past. I put a 3:73 rearend in from an '86 suburban so I could go fast(80mph). The wipers don't really press on the glass enough to work at high speeds in a downpour. I put on a newer wiper arm with the spring to hold it against the glass. Now the vacuum motor isn't strong enough to move the wipers back. I pulled out the vac motor and put some oil in it, that helped for awhile, but not enough. I have just installed a dual action fuel pump with vacuum generator. Ran the pipes, I like bending that tubing, it came out nice. Now when I start the engine, the gas flows out of the top and side of the carb like a fountain. I don't know if my old fuel pump was weak, and the new pump has found the carbs weak spots, or what? But I can't get it running long enough to test the wipers. I did a search here, and discovered, even with the vac gen, the vacuum wipers are not strong enough to move a wiper with a spring arm. And I need that spring arm wiper to hold the blade against the glass when I'm going 80mph in a downpour. So, it's time for electric wipers. When I opened the vacuum wiper motor and saw how it works, I was amazed. That is my favorite part of the truck. An engineering feat. Mechanically perfect. I guess I can put it on the wall and look at it. Was there a question... Oh yeah, does the dual action fuel pump have more pressure than, on second thought, I'll have a look inside that carb. | | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 |
| | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | I would install a part # 54 Purolater Pro-Fuel adjustable fuel flow regulator.The kit comes with everything you need.Mine works best at 4 psi even pulling a load.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Don't go 80 in a downpour! | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I agree with Ghostrider. Of course I have no desire to go 80 in a 60 YO truck on dry pavement with no other traffic. | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | You're gonna love the electric wipers!
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Mar 2007 Posts: 3,386 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,386 | I bought a kit for the 59" that has a delay switch and mounts just as the original. I found the ad in Custom Trucks. It was a little rich for my blood but it took all the guess work out and was a clean install. And Yeah I do love electric wipers.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | cheack your float it may be full off gas now | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | What kits have you guys bought? | | | | | Joined: Nov 2005 Posts: 324 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 324 | Darn it! I just replaced that float, five years ago, with a sixty year old one. I may try that fuel flow regulator, but I want to go fast in a downpour. and now that I have shocks on the front it doesn't walk two feet every time I hit a bump at 60mph. As terrifying as it was, I continued to tempt fate. Keeps the blood pumping. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | What kinda brakes you got on that thing? I still remember going down the freeway on the driverside 2 wheels in my 59 gmc. It was raining very hard, I pumped the brakes at 55 mph to slow down for the stopped traffic ahead, lost the back end, zigged and zagged a bit, and then proceeded to drive down the freeway at 45 mph with the passenger side up in the air. I still remember the look on the face of the driver next to me!  Any way, I did manage to get it back on all 4 and stop without hitting anything, and I have a great story to tell.  | | | | | Joined: Nov 2005 Posts: 324 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 324 | I do have a new master cylinder, but original, one chamber, if I loose one they all go. It's worked so far. I do have to drive like I'm fifty feet ahead of where I actually am, a buffer zone to give me time to react. Two wheels, that will get the blood pumping. I was on two wheels once, took a corner on a country road too fast late one night. I think the limited slip differential helped me that time. | | |
