0 members (), 77 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#2335 02/16/2005 5:31 AM
I have a '48 ¾ ton Chevy that I want to put disc brakes on. I don’t know of anyone that sells a disk brake conversion for a ¾ ton, so I was wondering if it’s possible to turn my spindles down so a ½ ton conversion kit would fit my stock spindles. I have access to a machine shop, and the work wouldn’t be a problem, but I’m not sure it’s even possible. My only other option would be to switch out my stock axle and spindles to a ½ ton axle set up. Which would be best in your opinion?
I am not concerned about keeping the original wheels.
As usual, thanks for the help everyone!
1948 3600 thriftmaster
#2337 02/16/2005 7:05 AM
try turning it down and if all fails get the 1/2 ton frount end
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
#2338 02/16/2005 5:30 PM
I have put 1/2 ton spindles on 3/4 ton axles sevral times by simply reaming out the bushings. Surprisingly the OD of the 1/2 ton bushing is larger so there is plenty of material. This will only work on the solid bronze bushings, the steel backed do not have enough bronze.
My Blog
