| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#23370 07/19/2003 3:05 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | I have an engine , removed from a '47 pickup , long side plate , 2 studs holding the rocker cover , casting # 838738 . This number was found behind the starter . Just in front of the starter is the # L127 , no other #s evident. I cannot find this # in any of my lists , has someone got a more complete list , to help I.D this engine for me please . Thanks guys . | | |
#23371 07/19/2003 6:23 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 |
#23372 07/19/2003 8:03 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | | | |
#23373 07/19/2003 9:36 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Dusty, are there any casting numbers near the fuel pump area? Oh yeah, book will be sent shortly
#23374 07/19/2003 10:12 PM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Thanks Ron , I thought perhaps it is a replacement block with that odd # , but wasn't sure. Luke no other #s on the block at all , thanks. | | |
