4 members (Hotrod Lincoln, Ranger, Peggy M, carbking), 44 guests, and 2 robots.
Topics128,035
Posts1,055,443
Members48,422
#233210 05/03/2007 9:15 PM
I installed the running board brackets onto my frame which is a 41 3/4 ton special, but the running board does not line up with the mounting holes on the bracket closes to the front of the truck. I don't remember any kind of shim to angle the bracket & I checked my pictures from dis assembly, but don't see any type of shim. I probably should of taken better pictures, anyway can anyone help me out. Thanks James
If it was easy, everybody would be doing it.
#233211 05/03/2007 11:15 PM
Not all the brackets are the same. The one in the front is bent forward. Make sure the brackets are in the correct location.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
#233212 05/04/2007 2:14 AM
My brackets are all the same.
#233213 05/04/2007 2:19 AM
i emails some photos that may or may not help
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
#233214 05/05/2007 5:12 PM
James, the brackets are not all the same, the front bracket on each side is longer (about 1 1/2 Inches longer) than the rear. If you your brackets are all the same the running boards will not lineup with the front fenders. Can send you a photo if you want.
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
#233215 05/05/2007 7:27 PM
James, sent you a photo of the brackets with some notes on the size.
