0 members (),
87
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 103 | I installed the running board brackets onto my frame which is a 41 3/4 ton special, but the running board does not line up with the mounting holes on the bracket closes to the front of the truck. I don't remember any kind of shim to angle the bracket & I checked my pictures from dis assembly, but don't see any type of shim. I probably should of taken better pictures, anyway can anyone help me out. Thanks James
If it was easy, everybody would be doing it.
| | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | Not all the brackets are the same. The one in the front is bent forward. Make sure the brackets are in the correct location. | | | | | Joined: Dec 2005 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 103 | My brackets are all the same.
| | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | i emails some photos that may or may not help
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | James, the brackets are not all the same, the front bracket on each side is longer (about 1 1/2 Inches longer) than the rear. If you your brackets are all the same the running boards will not lineup with the front fenders. Can send you a photo if you want.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
| | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | James, sent you a photo of the brackets with some notes on the size.
