| | | Forums66 Topics128,048 Posts1,055,666 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 3 Junior Member | | Junior Member Joined: May 2007 Posts: 3 | Was there ever a 67-72 production Duely, shortbed fleetside that did not have the fender flares? That is the Duelys were tucked inside the the bed fender wells? I saw one at a business about 20 years ago and did not know if it was a production model or a clever mod, either way it looked really cool. | | | | | Joined: Feb 2006 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 162 | I have seen a few of those around too, but dont know if they are factory or not.
Chris
1956 Chevrolet 4400 1959 Chevrolet Viking 60 1968 Chevrolet el Camino 2002 Chevrolet 1500HD 4x4
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Chevrolet used to have a model called Dooley but I don't recall ever seeing a Duely. | | | | | Joined: Feb 2006 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 162 | i think it was called "Big Dooley". Dooley is also my last name...cool huh?  I think the new "Dooleys" are called the standard "Dually" now.
Chris
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | GM didn't produce a dual wheel pickup with a regular type bed until the '73 model. Anything earlier will either be a cab/flat face cowl/cowl windsheild and chassis or a stake/flat bed. They also would have been made in the longer wheelbases on 3/4 or 1 ton chassis. I have heard of some GMCs that are made off the 1/2 ton short wheelbase with the 1 ton running gear, and even 4x4 versions, but have never seen one. Anything that you might see in a pre '73 is going to be an aftermarket conversion. There's several on the market. JCW still markets them.
Bill Burmeister | | | | | Joined: May 2007 Posts: 3 Junior Member | | Junior Member Joined: May 2007 Posts: 3 | Please excuse the misspelling of "Duely" instead of "Dually", after 1000mgs of Hydrocodone my self speller goes out of wack. (I was rear ended at a stop light while driving a sedan by a dummy in a early 3/4 ton Ford truck, driver stated his brakes went out.) | | |
