0 members (), 149 guests, and 2 robots.
Topics128,113
Posts1,056,619
Members48,450
#233010 04/30/2007 3:41 AM
Junior Member
Junior Member
Not much going on in the door section so I will post here.
The doors sag lower in the rear when closed or almost closed.
New pins, hinges are tight.
Could the cab be mounted improperly on the frame?
I am wondering if a slightly fatter rubber spacer in the front mounting location could possibly fix it.
Is there a way to shim the hinges?
Thanks as always.
#233011 04/30/2007 1:05 PM
Z
Z Offline
The only way to adjust the hinges on a 46 is to use heat/force to bend them. You actually need to tweak the hinges in order to adjust your doors. It takes some time an patience to get it right.
1946 Chevy Pickip
#233012 04/30/2007 4:02 PM
Over...
I have scanned some pages out of a GMC service manual that covers how to adjust your doors, among other things. It does take some bending of the hinges. No heat needed. You will need a piece of 2x4 and a big "C" clamp. I used these instructions when I was working on my 46. It really works.
I can email it to you if you want. Just contact me directly.
George
#233013 04/30/2007 5:12 PM
Mine did the same. A piece of 2x4 just below the bottom hinge did the trick. I place the 2x4 there and then attempted to shut the door. Do this with light pressure at first. After several pushes on the door it lined right up.
