| | | Forums66 Topics128,100 Posts1,056,177 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#23292 04/03/2002 3:24 PM | Joined: Mar 2002 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 126 | Hello fellow Stovebolters. I have a 42 PU with a Carter W-1 carb. It seems to work fine other than it is leaking gasoline out both sides of the throttle shaft (shaft going through carb with throttle valve). I really cannot see what prevented gas from leaking here in the first place. The shaft just slides through carb with no seals or ??? Anyone ever have this problem or know what I can do to solve it. Thanks in advance. Chris
Chris Simmonds 1942 Chevy 3/4 ton | | |
#23293 04/03/2002 4:11 PM | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | Might be time to re-bush your throttle shaft. Or did you do this already? Common problem on old carbs, especially Q-Jets.
*** GMC ***
#23294 04/22/2002 2:51 AM | Joined: Apr 2002 Posts: 6 Member | | Member Joined: Apr 2002 Posts: 6 | i would check the float level first,then check to see if when running any fuel may be bleeding down carb throat when idling.both would be float problems | | |
#23295 05/06/2002 11:31 PM | Joined: Sep 2001 Posts: 13 Member | | Member Joined: Sep 2001 Posts: 13 | yup sounds like you need to get that choke sleeve re done. Its not bad. National Chevy Association has a deal where you send in yours and the redo it totally top to bottom for $140. hope it helps.
justin kohut 1950 fleetline/kustom 1950 Buick super (straight eight)
#23296 05/07/2002 1:15 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | . Wingnut is on the right track. The fuel has to come from somewhere!!! .I am not saying that the throttle shafts are not worn,but the fuel has to be overflowing the float-bowl to get to the throttle shaft.
#23297 05/07/2002 6:24 PM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Heck! They all leak, don't they? My "newer" ones all leak and at top gasket too. After it leaks a while it turns black and varnish like and "seals" up the leak. No more problem, just ugly!  :rolleyes:
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
