4 members (UtahYork, cmayna, Otto Skorzeny, Bucker), 111 guests, and 0 robots.
Topics128,162
Posts1,056,916
Members48,458
I just picked up a 65 C30 it has a stright 6 but not sure which the 65 manual says that if it is green then a 292 well it looks green but would like to find a number on the block to confirm this. Numbers I found are F1120B just above the disreibuter,
CON 2 J 10 3 on the rear of the right side of block
3850817 GM 14 on the center of the right side of block.
On the intake manifold 3859381 GM12 and also on the intake man near the fire wall D195.
There is a number on the head but having some trouble reading it maybe 488381F.
The truck runs well I drove it home about 70 miles body needs the usual patches rockers,cab floor bottom of hood and paint, only complaint is the dash was cut to fit in a modern radio but if I remove the radio it looks like a delete plate will cover it. I will post some photos or a link to some this weekend
Ed
Easiest ways to tell if it's a 292....side covers are 6" high.
Passenger side engine mount is in front of the fuel pump. The mounts are staggered by about 3 1/4".
Steve
'49 3800
'52 3600
'57 3100
Well the side plates measure 4.5" and mount is in rear of fuel pump so I guess its a 230 here is a link to side of engine
http://oldmopar.com/oldgmcs/pics/engineR.jpg
and here is a link to pics of the truck
http://oldmopar.com/oldgmcs/65C30pics.html
It could be a 194, 230 or 250. They are all dimensionally the same on the outside.
I do find it strange that GM did not put any marks on the engine to id it. From what I have read they only used a 250 and 292 in 65 and as this has low miles it should be the original engine so I guess I will go with 230.
Ed
If it is the original engine, there's a pretty good chance it is a 230. The 250 and 292 were made for many years, not just 1965.
There should be an engine ID on the distributor pad, if not then the engine may have been replaced under warranty with a generic(?) by the dealer.
Larry
I don't own a vehicle that isn't old enough to drink.
The number on the pad above the distributer is
F1120B
The 250 started in 1966, from 63-65 they used the 230.
