1 members (Ponchogl), 163 guests, and 3 robots.
Topics128,101
Posts1,056,182
Members48,436
#23292 04/03/2002 3:24 PM
Hello fellow Stovebolters. I have a 42 PU with a Carter W-1 carb. It seems to work fine other than it is leaking gasoline out both sides of the throttle shaft (shaft going through carb with throttle valve). I really cannot see what prevented gas from leaking here in the first place. The shaft just slides through carb with no seals or ??? Anyone ever have this problem or know what I can do to solve it. Thanks in advance.
Chris
Chris Simmonds
1942 Chevy 3/4 ton
#23293 04/03/2002 4:11 PM
Might be time to re-bush your throttle shaft. Or did you do this already? Common problem on old carbs, especially Q-Jets. smile
*** GMC ***
#23294 04/22/2002 2:51 AM
i would check the float level first,then check to see if when running any fuel may be bleeding down carb throat when idling.both would be float problems
#23295 05/06/2002 11:31 PM
yup sounds like you need to get that choke sleeve re done. Its not bad. National Chevy Association has a deal where you send in yours and the redo it totally top to bottom for $140. hope it helps.
justin kohut
1950 fleetline/kustom
1950 Buick super (straight eight)
#23296 05/07/2002 1:15 AM
. Wingnut is on the right track.
The fuel has to come from somewhere!!!
.I am not saying that the throttle shafts are not worn,but the fuel has to be overflowing the
float-bowl to get to the throttle shaft.
#23297 05/07/2002 6:24 PM
Heck! They all leak, don't they? My "newer" ones all leak and at top gasket too. After it leaks a while it turns black and varnish like and "seals" up the leak. No more problem, just ugly! grin :rolleyes:
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
