7 members (dt235sd, sron48, Keepinthemstockm, TUTS 59, Wally / Montana, Jay R, 1 invisible), 89 guests, and 2 robots.
Topics128,084
Posts1,056,333
Members48,442
#232826 04/28/2007 6:58 PM
After a lot of thought on this, I FINALLY decided to upgrade Dusty's rear end. I got on the phone yesterday and called MY favorite parts supplier, Classic Parts Of America, and spoke with a VERY knowledgeable and helpful "ANGIE" (X-245) about getting all the right items to complete my upgrade. I ended up ordering the 3.38 to 1 Ring & Pinion gears, the complete installation kit and the differential carrier and rear cover gaskets. Running a stock 235 won't put me in the "fast lane", I know, but the higher ratio should at least give me a better top end (with lower RPM), and save somewhat on gas. Anyone out there that has completed this upgrade, and can pass along their insight on the installation and results?
Riding in the Passing Lane
I did it on a 56 about 2 years ago. Makes a whole different truck out of it. With a good 235 you will be able to go out there & run 65-70. Make shure you get the tooth pattern right. They come with good instructions & there are plenty of guys on the websight that will help. I wanted to put a set in the 58 I have now but they weren,t available for a long time so I put in a T-5.
1972 Chevy c10 Cheyenne Super
Wrencbender--Thanks for the reply! I'm running a completely rebuilt 235 (with only 1300 miles on the speedo since rebuild), so yep, it is a strong motor. Will be looking forward to seeing how much better the truck performs with the new rear end! I will take your advice about the tooth pattern being correct, and appreciate the advice. wink
P.S. I'm "Ret." also--isn't it GREAT? grin grin grin grin grin
