| | | Forums66 Topics128,049 Posts1,055,651 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 31 New Guy | | New Guy Joined: Dec 2006 Posts: 31 | It's been a while since my last post, but here it goes anyway. I am in the process of rebuilding the bed of a 1958 Chevy Apache step side. I have removed all of the deteriorated wood and bed strips and have a question about removing the angle strips so that I can replace with new units. Does anyone have any prior experience or help with the removal and reinstallation of new angle strips | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | They are spotwelded on. You will have to drill out the spot welds to remove them.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Dec 2006 Posts: 31 New Guy | | New Guy Joined: Dec 2006 Posts: 31 | Are they spot welded from the back side? All I see is one bolt holding each one in place from the outside. | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | I guess you could say they are spot welded from "both sides". It's not really a tack weld, but a resistance weld from current through two copper electrode tips that are squeezing the two parts together. The weld is actually formed internally, so they are not as visible to the eye as other welds. Get a spot weld cutter and drill from the side you don't need to save. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | I drilled the welds out from the outside of the bed. All but two of the new spot welds were under the rear fender so those did not get dressed out as well as the two visible welds since I am going to undercoat that area. | | | | | Joined: Mar 2001 Posts: 279 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 279 | If your's is like my '53, I used a spot weld cutter. Works great. I located the spot welds on the angle strip side of the bed by putting a flat tip screw driver between the bed side and the angle strip. Once located, just drill using the spot weld cutter and it works slick. At least that's how I recall doing it, but then it's been a few years. Doing it that way kept from messing up the side panels of the bed. | | |
