1 members (Woodcmiami),
72
Mod | | | Forums66 Topics128,031 Posts1,055,433 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 81 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 81 | Can anyone tell me the proper location for a radio antenna on a 52 3100?
52 Chevy 3100 5 Window, LS Swap, 4spd Auto, Vintage Air AC / Heat, CPP Power Front Disc Brake Conversion with bearing upgrade, Power Steering Conversion, LED Tail Lights
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | I think there was a recent post on the subject of antenna location. The person didn't have the nice template Curt linked, but eyeballed it pretty close...then they opened the hood and saw how close they came to disaster.
Stuart | | | | | Joined: Mar 2007 Posts: 81 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 81 | Thanks guys, I appreciate it.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Antennas were shipped to the dealer in trunks of cars and cabs of trucks and installed by a "get ready man". I wish I had a dollar for all I installed during my stint in that position. Many times the buyer would request the antenna be placed in other locations than that recommended by the manufacturer.
~Jim
| | | | | Joined: Apr 2007 Posts: 146 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 146 | You can purchase a "hidden" antenna, so you dont have to drill new holes. Hooks up to the old "style" radios as well.....
Chey LOST1953 My favorite color is CHROME The ugliest trucks are driven by the prettiest girls  I dont suffer from insanity, I enjoy it! O Lord, WHY did I buy another "Thing"? (again??) ---- 1953 Chevy 3800 1-ton Gallery More photos at MSN ----
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Larry,
Thanks...seems I do have some mid-term memory still working.
Stuart | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | My truck has a hole in the cab where the PO put it. It hit the hood. Its got a chrome plug in it now but I'm going to patch it up right when I repaint it.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I saw a neat way to get around 4ontheFloor's problem. The guy had an electric antenna. He had an internal regulated alternator and didn't need the generator regulator so he gutted it and put a push button switch in it. I forget what kind of mechanism did it but when the hood closed it closed the switch so the antenna could operate normally. With the hood open so was the switch, breaking the circuit. If he turned on the ignition without remembering to turn off the radio, no damage done. | | | | | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | I drilled the antenna hole even before priming, and of course there was no hood on either, but I never dreamed it would cause Me any problems.. It would have been nice to have a template to locate exactly where it goes...I just bought an antenna with a screw-off mast, then when I raise the hood I'll have to un-screw the mast...Bill B | | | | | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | I just purchased an original repop antenna from the Truckshop and the rubber washer that goes between the mast base and the cab has a raised rib around the outside, like almost all washers I have seen for this type of application. Except here, it only goes around maybe 3/4's of the way around and is just flat at the remaining 1/4. Is this just a defect, or is this designed to either, fit against the cab beltline, or orient downward as a kinda of drain???? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | It fits against the cab beltline. | | |
