2 members (Bill Hanlon, baldeagle), 109 guests, and 4 robots.
Topics128,186
Posts1,057,317
Members48,469
I have a fairly stock GMC 1/2 ton pickup that includes a few modifications. I have installed a stainless steel gas tank under the bed between the rear end and bumper area. I have also converted over to standard shocks front and rear. I have a 302 GMC that I plan on adding duel exhaust and fentons. Does anyone out there make a custome mandrel bent stainless steel exhaust system without having to bolt the entire truck together and trailer it to a fab shop?? I dont want to buy elbow, cut and weld if I can avoid it. Any suggestions would be appreciated.
Steve
You might check with Patrick's - his catalog lists a stainless exhaust system with a Bassani dual inlet/outlet muffler. Whether it would fit a '45 is the question. It's supposed to fit AD '47-'54 trucks, and there are some differences in bellhousing crossmember and overall dimensions. But it would be a good place to start.
