| | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 125 | Where should the lower rear shock absorber mount be on a 51 GMC 1/2 ton? Is the mount attached to the front or rear U-Bolt on the leaf spring. Even though the upper mount on the frame looks like it is angled towards the rear u bolt on the spring, the shock absorber is only long enough to reach the front U-bolt, leading me to believe that that is its location. Is this correct? Here is a picture of what I am talking about: http://good-times.webshots.com/photo/2467561150100058208TEOkUM | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | It attaches near the forward U-bolt. | | |
