| | | Forums66 Topics128,089 Posts1,056,367 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 1 Junior Member | | Junior Member Joined: Apr 2007 Posts: 1 | Hi I recently bought a rebuilt (long) waterpump for a 55 235 engine, which has the 4 mounting holes but does NOT have the 1/2 inch water hole for water (looks to come from head in the engine block.)question is this hole supposed to be in the water pump or are some pumps built without it on purpose ? Looks easy enough to drill a hole in the pump to match up but don't want to if it is NOT supposed to be there. seen some pictures of water pumps with the hole. thanks for any help John | | | | | Joined: Sep 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 310 | Can't help you there, but this answer will bump it to the top again, there must be somebody out there that loves the '55 Good luck | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Sounds like you are referring to the heater feed outlet. I've never seen or heard of one without it. | | |
