1 members (Cletus1950),
77
Mod | | | Forums66 Topics128,151 Posts1,057,000 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#23131 01/03/2005 9:55 PM | Joined: Jun 2004 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 37 | I am taking the engine from my 1954 have it stripped down to the block and head. I have removed all clutch, and shifter links and have the mounts loosened. I took the ball cap off the transmission rear end per the 1954 Workshop Manual. It now instructs to push the ball cap back on the torque tube to access the trunnion connections. This baby aint "slippin' nowhere. There is a serrated collar at the rear that looks like a locking collar. Do I need to unscrew the collar to allow the entire ball cap to move along the torque tube? Please bear with me I've never worked with one of these "closed" tubes before. Thanks
My rule of life: You can have anything you want; you just can't have everything you want.
#23132 01/03/2005 10:36 PM | Joined: Jun 2004 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 103 | Yes - The collar must be loosened to allow the ball / collar to slip on the shaft. Once it is back, you can unbolt and "slip" the joint. Watch out for the pint of oil / grime that is in the ball. BW | | |
