0 members (),
66
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#23095 02/05/2002 6:32 AM | Joined: Feb 2001 Posts: 41 Member | | Member Joined: Feb 2001 Posts: 41 | I have noticed that some 235s have valve covers that bolt to the head around the outside of the valve cover (as is common on most engines), while some bolt on two big posts that come up through the middle of the valve cover. Does anyone know which years used which?
Thanks, Ed | | |
#23096 02/05/2002 6:51 AM | | Anonymous Unregistered | | Anonymous Unregistered | The early 235's [ pre- 53 ] used the same valve cover as the 216 with the 2 acorn nut attachment in the center of the cover. In 1954 [ & some late 53's ] The high pressure 235 was introduced & the valve cover used the 4 bolts on either side. | | |
