2 members (greenie-reddy, KEVINSKI), 116 guests, and 6 robots.
Topics128,266
Posts1,058,367
Members48,485
#230602 03/30/2007 2:57 PM
I am hoping for some advice on the removal of the lower ball joints for my '66. The uppers were easy to grind off the rivets, but what about the lowers?? Are they threaded or press fit?
G in Mich
GS
#230603 03/30/2007 9:15 PM
They are pressed in...On my 66 1T I used to have, I
supported the lower arm and smacked them out with
a 5# hammer..
Geoff
68 GMC 3800
56 JD420C w/JD90 Loader
#230604 03/30/2007 10:26 PM
Riding in the Passing Lane
Stick is right. Support it with a stand or jack close to the ball joint & hammer it out. I use a similar way going back but the purists will shudder. I put a heavy metal under the ball joint & jack it up under the metal to get spring tension on it. Then I take the same hammer & a large bar or drift & hammer the a-arm down. Do it at your own risk.
1972 Chevy c10 Cheyenne Super
#230605 03/31/2007 1:07 AM
Rent a balljoint press from the flaps. They're not to hard to use, kind of like a really heavy duty C clamp.
Bill Burmeister
#230606 03/31/2007 5:05 PM
Well, the A arm is out of the truck so I will try to put it in the vise and hammer it out.I have new ones from LMC so they look like a fit.
If I can't get them out I will take them to a shop. thanks again.
GS
#230607 03/31/2007 5:20 PM
J M Offline
If you have the lower control arm out a press will make that a quick and simple job both removing and installing the new joint.
Good luck
Jim
#230608 03/31/2007 9:36 PM
Now is a good time to do the bushings, if your "A" arm has them.
#230609 04/01/2007 4:13 AM
Thanks so much guys. I have the bushings so will do the complete job. Appreciate the tips as always on this project.
GS
