2 members (Goach2, 1 invisible), 93 guests, and 2 robots.
Topics128,092
Posts1,056,457
Members48,443
#23024 03/23/2004 11:50 PM
Truck runs fine for about 3 miles then starts to miss, doesn't accelarate, runs really rough. When I check the plugs they are black with carbon, heads were rebuilt completely, new carb, wires, caps, everything. Some say it's the carburator, others is the valves, others the manifold spring. I have no clue. Any suggestions, since I have no specific mechanic, I would like to know atleast what it could be before I take it in for professional help and get raped. My brother and law started it for me and then got deployed. Thanks
1950 3100
1980 "Vette"
2005 Mustang GT
http://community.webshots.com/user/jlr1516
Fouled plugs are an indication of overly rich mixture and/or late timing. Check the timing and point gap first. Then check the valve lash warm. Finally, check the carburator. It sounds like you might have a stuck power valve or too rich a jet for your engine.
A Rochester "B" should have a 53 or 54 main jet for a 235 and a 57-58 main jet for a 261. The power piston should move freely and hold the ball off the seat when the engine is not running, but should get sucked up into the airhorn and let the ball seat with about 7 lbs of vacuum. The correct gaskets are required for the power valve to work. The most overlooked one is the spacer on the manifold, it should have notches to line up with the small hole on the base of the carb. The other overlooked ones are between the throttle body and the bowl, and between the air horn and the bowl. Make sure none of the passages are plugged.
A stuck manifold heat valve causes a lean condition when the engine is warm.
Paint & Body Shop moderator
If the carb is running rich to the point where the plugs are fouling after three miles then there should be a lot of black smoke coming out the tailpipe. If not, your ignition coil may be weak, i.e. not enough spark.
Yea alot of black smoke, I haven't changed the coil, should I?
1950 3100
1980 "Vette"
2005 Mustang GT
Make sure your choke plate is opening all the way and that the choke linkage is not sloppy enough to allow it to close.
Make sure you have the correct spark plugs, yours may be too cold for your driving, but cold plugs don't normally cause fouling that fast.
To foul in that short a distance has to be caused by an excessively rich mixture.
'31 Chevy 1 1/2 ton,
'42 GMC 2 1/2 ton 6x4,
'52 GMC 2 1/2 ton 6x6,
'53 GMC 5 ton
