5 members (tclederman, DadsFirstPickup, 59 fleet, IHPWR, Ponchogl), 102 guests, and 4 robots.
Topics128,107
Posts1,056,225
Members48,436
#230135 03/23/2007 3:20 PM
Well after useing the search mode many times I figuard that I need to come out of lurk-er mode.
I'm have currently taken dents out of my 235 pan and I was wondering if it work-hardend the metal, it sits fairly flat on a mock-up block. SO the question is. would it be wise to anneal the pan, Mostly around the bottom. to let it relax. ohwell
#230136 03/23/2007 3:27 PM
T-RUCK,
If you have already hammered the dents out of the pan and no further hammering is required, then it is a moot point if it is work hardened. I don't know if low carbon steel like the pan stamping will work harden at all, but it would only cost the price of the oxygen and acetylene to anneal it, and it might give you piece of mind.
Stuart
#230137 03/23/2007 3:37 PM
Thanks Stuart
I guess it is moot but I was looking getting it to sit flater on the block, SO I thinking FLAME ON.
