8 members (Ponchogl, Peggy M, Gray_Ghost, David Bush, TooMany2count, Tronman, JW51, Wayne67vert), 94 guests, and 2 robots.
Topics128,052
Posts1,055,716
#229945 03/22/2007 5:00 AM
I read all the threads on updating to the modern tie rod ends. Today I went to NAPA to get a set of the Moog ES29L and ES29R and discovered that NAPA no longer carries them because they have been deemed obsolete.
Does that mean that I've use a tapered tie rod ends and get the correct tapered reamer for the steering bellcranks?
#229946 03/22/2007 5:19 PM
i may have a nos set in my stock email me at [email protected] if your intersted
1949 SUBURBAN
#229947 03/22/2007 9:42 PM
Riding in the Passing Lane
I believe Carquest still has them. The specialty suppliers do.
1972 Chevy c10 Cheyenne Super
#229948 03/23/2007 11:51 PM
i have an original NOS set (Moog ES29L and ES29R) still in their original boxes && do not need them.
Jim & Caroline
#229949 03/24/2007 11:41 AM
I don't know if these numbers will help, but you can try them and comment.
LH Tie Rod GM# 374227 or Moog ES29L female thread
RH Tie Rod GM# 374226 or Moog ES29R female thread
drag link GM# 367528 or Moog DS-91 double male thread
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
