0 members (), 155 guests, and 4 robots.
Topics128,110
Posts1,056,241
Members48,437
#229940 03/21/2007 3:56 AM
Junior Member
Junior Member
How long are the fabric straps that attach the hood props to the hood? I have a pair of original GMC hood props and there is was a piece of fabric similar to flat hood lacing, about 3/4" wide and 1/8" thick, one end of the strap was bolted through a hole in the fabric strap and the metal hood prop and the other end of the fabric wrapped around the hood latch rod and the fabric itself was bolted together.
#229941 03/21/2007 3:49 PM
Those things are rare, I've only seen one set that even had the straps. If you don't get an answer you could figure it out as the strap picks up the hood prop as you lift.
Best of luck
1946 1/2-Ton Chevy
