3 members (Guitplayer, Charles in CA, 1 invisible), 65 guests, and 2 robots.
Topics128,030
Posts1,055,418
Members48,422
#22985 05/01/2002 2:46 PM
Does anybody know what the wheelbase WIDTH is on an original 54/55 half ton -- from outside of tire to outside of tire. U-Haul's giving me some trouble on a car carrier; claims it's too wide.
thanks in advance, jerry
#22986 05/01/2002 6:27 PM
' Offline
Hey Jerry,
Don't know if '54 and '47 are exactly the same; but, Chevy's restoration guide for the '47 AD gives 56 9/16 for the front with 6.50-16-6 ply and 57 11/16 for 15" 6 ply. It says the rear widths are 69 3/4 and 70 3/4 respectively. Hope this helps.
Regards,
A great lady, a stovebolt, & a small town! What else is there?
Aspiring '54 6400 dump truck owner
'Bolt On
#22987 05/01/2002 6:41 PM
E mail the Kook [email protected]. He hauled his '51 GMC to Carlisle last year on a U haul trailer..
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#22988 05/02/2002 12:08 AM
I ran out and measured my 54. I got 73 inches. It should be not much different than a modern truck.
if it dosen't need fixed, break it
#22989 05/02/2002 2:49 AM
thanks all. Kedso, I think your measurement is probably right for the '55 1st series too. U-Haul tells me that it is 80 inches. That just didn't seem right. I know the cab was called the "six footer" but 6'8" seems a bit much.
It just occurred to me that their concern might be the running boards since the rails are below the fenders. Kedso, would it be possible to measure outside to outside at the running boards?
thanks all, jerry
#22990 05/02/2002 5:37 AM
Anonymous
Unregistered
Anonymous
Unregistered
Widest part of the truck is the rear fender bead where it wraps around from the running boards to the wheel opening at 74-3/4 inches. Before I bought my own trailer, I hauled several AD trucks (including suburbans) on U-Haul Trailers. The truck only weighs 3200 lbs max . . . it will be fine. The problem is that if they punch it up in their computer and it doesn't say what they want to see . . . you are outta luck.
#22991 05/03/2002 12:12 AM
Sorry I left to watch star trek. The total width of my 54 is 75 or 76 inches. Let me know if you need any other info
#22992 05/03/2002 1:21 AM
Hardwareguy,
Last fall I had the problem with U-Haul since their computer idn't go back to 1948. I wound up getting a trailer from Penske and put the 48 Burb on it, no problem. Their trailer was 2 inches wider than a u-haul, cheaper, and no flack about the year.
JohnRJoyner
48 Suburban,55 1st 1/2 ton, 53 GMC
